Status Codes For Status
  • October 2, 2023
  • 79 views
I’m curious if anyone has encountered the issue of decoding the status codes for vms and other api endpoints for protection status.
For example:
"vmStatus": 1
I know these typically are 1-6 but could commvault support provide a mapping for each of these to help us determine what this means for protection status? Also, if it differs for vm clients to db clients, what should I expect from those as well?
PS - I did see this topic /webconsole/api/v2/MediaAgents status and offlineReason codes and it was close to what I was looking for but this was for MediaAgents where I’m specifically concerned with VMs and DBs
Best answer by Navneet Singh
@Aaron Brockmeyer
Hi Aaron Please find the status codes for the VM in API.
  • 0, All
  • 1, Protected
  • 2, Not Protected
  • 3, Pending
  • 4, Backed up with error
  • 5, Discovered
https://api.commvault.com/#734d6b5e-cebf-42b2-b673-7af1449082b5
6: Failed
7: Protected (warning)
Forum|alt.badge.img+13
  • October 3, 2023
@Aaron Brockmeyer
  • 0, All
  • 1, Protected
  • 2, Not Protected
  • 3, Pending
  • 5, Discovered
6: Failed
