Strange issue with SQL query within workflows
  • November 12, 2024
  • 78 views
christopherlecky
Explorer
Forum|alt.badge.img+21
When I run the following query in SQL it returns a single value that is an XML representation of the client list.
SELECT
[Client].[Id] 'ClientId',
[Client].[name] 'ClientName',
[Client].[net_hostname] 'ClientHostName'
FROM
[CommServ].[dbo].[APP_Client] AS [Client]
WHERE
[Client].[status] = 2
FOR XML RAW, ROOT('ClientInfo');
The goal is to use xpath to do queries against the list rather then doing constant queries.
The problem is that when I run it in a workflow it looks like it paginates the results so it returns multiple rows.
Is there another way to do this?
  • July 11, 2025
Hi ​@christopherlecky
Commvault Workflows execute an XPath query Usually via XML Query activity or script, and the input XML contains a list, the workflow engine may iterate over each matching node as rows, not aggregate them as one array or list.
This can look like pagination, but it's really row-wise iteration, depending on how the For each or activity is configured. Try to Set the output as a variable of type List or XML
