subclient Id is different on url and API gives different ID
  • May 29, 2024
  • 113 views
  • I need an API endpoint to fetch the subclient id.
  • For testing purpose I copied the ID from the url: https://win-igicqf1affn/commandcenter/#/collectionDetails/content/3/10
  • In the above mentioned URL 10 is the subclient id. I have used it in other API endpoints.
  • But when I use the api in order to fetch the subclient id it gives me 14 instead of 10.
  • Below are the links to APIs I have been manipulating.
https://api.commvault.com/docs/SP34/api/cv/VirtualizationOperations/update-subclient-virtual-machine-content
https://api.commvault.com/docs/SP34/api/cv/SubclientOperations/get-subclient-properties
  • The api that is giving me a different subclient id:
https://api.commvault.com/docs/SP34/api/cv/SubclientOperations/get-subclient-id
import requests
import json
url = "https://win-igicqf1affn/commandcenter/api/subclient?clientId=8"
payload={}
headers = {
'Accept': 'application/json',
'Authtoken': 'token'
response = requests.request("GET", url, headers=headers, data=payload, verify=False)
pretty_json = json.loads(response.text)
data = json.dumps(pretty_json, indent=2, sort_keys=True)
print(data)
c:\APIs>py GetSubclientId.py
C:\Users\Ansible_user\AppData\Roaming\Python\Python312\site-packages\urllib3\connectionpool.py:1103: InsecureRequestWarning: Unverified HTTPS request is being made to host 'win-igicqf1affn'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#tls-warnings
warnings.warn(
"filterQueryCount": 1,
"subClientProperties": [
"analyticsSubclientProp": {},
"cassandraProps": {},
"dcPlanEntity": {},
"dfsSubclientProp": {},
"planEntity": {},
"proxyClient": {},
"region": {},
"splunkProps": {},
"subClientEntity": {
"_type_": 7,
"appName": "Virtual Server",
"applicationId": 106,
"backupsetId": 12,
"backupsetName": "defaultBackupSet",
"clientId": 8,
"clientName": "Ash_win19",
"commCellName": "win-igicqf1affn",
"csGUID": "AED8C433-93CB-4A67-80C9-FFFCD116C127",
"displayName": "Ash_win19",
"entityInfo": {
"companyId": 0,
"companyName": "Commcell"
"instanceId": 2,
"instanceName": "VMInstance",
"subclientGUID": "AA990D70-538D-401F-A6E1-9FCC9A01A647",
"subclientId": 14,
"subclientName": "testing_tobedeleted"
"taPlanEntity": {},
"useLocalArchivalRules": false,
"useLocalContent": false
        "subclientId": 14,
  • The above subclient id retrieved from API doesn’t work whereas the one on the url works perfectly.
  • Are they different IDs? What API to use to get the correct subclient id that actually works?
Best answer by RandomCustomer
In both the above api calls subclient entity is different:
"_type_": 7,
"backupsetId": 8,
"clientId": 3,
"clientName": "lol",
"displayName": "lol",
"entityInfo": {
"companyId": 0,
"instanceId": 4,
"instanceName": "VMware",
"subclientGUID": "A4D866FE-CCEB-4C6C-9ABC-B9406CE43FF3",
"subclientId": 10,
"_type_": 7,
"backupsetId": 12,
"clientId": 8,
"entityInfo": {
"companyId": 0,
"instanceId": 2,
"subclientId": 14,
One has Vcenter as client and other has VM as client. By running the get subclient id I am getting the Subclient id for VM Ash_win19 entity and not for Vcenter. The Vcenter one is the correct one.
After checking further. When I use the API to fetch subclient properties using the subclient id from url i.e.10 and subclient id from api call i.e.14 I get 2 different output but subclient name remains the same.
Below output is with id 14:
"canChangeEncryptionSetting": false,
"commonProperties": {
"UNCScriptCredentialinfo": {
"credentialId": 0,
"credentialName": ""
"allowVssForSnapbackup": false,
"associatedPolicy": {
"subclientPolicyId": 0
"associatedSnapShotSCId": {
"_type_": 7
"dedupeRatio": 0,
"disableArchivingTurboRule": false,
"enableBackup": true,
"enableBackupAfterDelay": false,
"enableBackupAtDateTime": {
"TimeZoneID": 0,
"time": 0
"encryptionFlag": 2,
"firstBackupTime": 0,
"guestCredentialinfo": {
"credentialId": 0,
"idaType": 0,
"impersonateUserCredentialinfo": {
"credentialId": 0,
"indexCycleToEveryBackupJobs": 100,
"indexingBackupSubClient": false,
"isActivityDisabledFromPolicy": false,
"isAdAppAwareSubclient": false,
"isDefaultSubclient": true,
"isETCDSubclient": false,
"isTrueUpOptionEnabled": false,
"lastBackupSize": 0,
"lastBackupTime": 0,
"nextBackupTime": 0,
"numberOfBackupStreams": 5,
"onBoardCompanyId": 0,
"prepostCredentialinfo": {
"credentialId": 0,
"prepostProcess": {
"prepostUserName": {},
"runPostBackup": 0,
"runPostLog": 0,
"runPostScan": 0
"runAs": 0,
"runTrueUpJobAfterDays": 30,
"security": {
"advancedPrivacySettings": {
"authType": 1,
"isPasskeyFeatureEnabled": false,
"isPrivacyFeatureEnabled": false,
"passkeySettings": {
"enableAuthorizeForRestore": false,
"expirationTime": {
"time": 0
"associatedUserGroups": [
"_type_": 15,
"userGroupId": 1,
"userGroupName": "master"
"ownerCapabilities": {}
"securityAssociations": {
"ownerAssociations": {},
"tagWithCompany": {
"providerDomainName": "Commcell",
"providerId": 0
"sizeOnMedia": 0,
"slaCategory": 0,
"slaCategoryDescription": "N/A",
"slaStatus": 3,
"snapCopyInfo": {
"IsOracleSposDriverEnabled": false,
"configuredSybaseInstance": {
"_type_": 5
"isRMANEnableForTapeMovement": false,
"isSnapBackupEnabled": false,
"quiesceImpersonateUser": {},
"separateProxyForSnapToTape": {
"_type_": 3
"snapToTapeProxyToUse": {
"_type_": 3
"snapToTapeSelectedEngine": {
"_type_": 110
"sqlUser": {},
"sshKey": {},
"sybaseUser": {},
"useProxyForSQLIntegrity": {},
"vmApplicationUser": {}
"storageDevice": {
"dataBackupStoragePolicy": {
"_type_": 17,
"storagePolicyId": 4,
"storagePolicyName": "testing"
"deDuplicationOptions": {
"enableDeduplication": true,
"generateSignature": 1
"logBackupStoragePolicy": {
"_type_": 17
"performanceMode": {
"enableMultiplexing": false,
"lookAheadReaderSlots": 4,
"multiplexingValid": false,
"muxFactor": 0,
"numOfPipelineBuffers": 180,
"perfCRCDetails": [
"crcOverMedia": true,
"crcOverNetwork": true,
"perfMa": "win-igicqf1affn",
"perfMaId": 2
"perfClientName": "Ash_win19",
"perfCopyName": "Primary",
"perfSPName": "testing",
"pipelineBufferSize": 64,
"streamsOverMux": false
"subClientPropertiesFlag": 0,
"subclientPolicy": {
"_type_": 65,
"subclientPolicyName": ""
"totalBackupSize": 0,
"turboNASClient": {
"_type_": 3
"vmBackupValidationSettings": {
"backupValidationThreadCount": 0,
"isAppValidationEnabled": false,
"isCustomAppEnabled": false,
"runAsDevTestGroup": false,
"subTaskId": 0,
"taskId": 0,
"uncScriptImpersonateUser": {
"userName": "0"
"useSourceVMEsxToMount": false
"dcPlanEntity": {},
"hcSubclientProp": {},
"planEntity": {},
"proxyClient": {},
"region": {},
"splunkProps": {},
"status": 2097160,
"_type_": 7,
"backupsetId": 12,
"clientId": 8,
"entityInfo": {
"companyId": 0,
"instanceId": 2,
"subclientId": 14,
"taPlanEntity": {},
"useLocalArchivalRules": true,
"useLocalContent": false,
"vmBackupInfo": {
"vmBackedUpWithErrorCount": 0,
"vmNeverBackedUpCount": 0,
"vmNotProtectedCount": 0,
"vmPendingCount": 0,
"vmProtectedCount": 0,
"vmTotalCount": 0
"vmContent": {},
"vmDiskFilter": {},
"vmFilter": {},
"vsaSubclientProp": {
"appBasedBackup": false,
"customSnapshotResourceGroup": "",
"customSnapshotTags": {},
"datastoreFreespaceCheck": true,
"destinationAccount": {
"amazonClient": {}
"proxies": {},
"proxyESXServer": {
"vsInstance": {
"clientId": 3,
"instanceId": 4,
"regionalSnapshot": true,
"useChangedTrackingOnVM": false,
"useVMCheckpointSetting": false
Below is after I run the api using id 10:
  warnings.warn(
"credentialId": 0,
"allowMultipleDataReaders": false,
"_type_": 7,
"subclientId": 0
"dedupeRatio": 76.44684,
"TimeZoneID": 0,
"time": 0
"firstBackupTime": 1716350412,
"credentialId": 0,
"idaType": 0,
"credentialId": 0,
"lastBackupJobInfo": {
"commCellID": 2,
"endTime": {
"time": 1716868812
"failureReasonIds": "38,",
"failureReasonMessageEnglish": "All activity on CommServe is disabled. The job will not run because activity is disabled.<br>Source: win-igicqf1affn, Process: JobManager",
"jobID": 66,
"startTime": {
"time": 1716868812
"status": 9
"lastBackupSize": 573675003,
"lastBackupTime": 1716782416,
"credentialId": 0,
"prepostProcess": {
"runPostBackup": 0,
"runPostLog": 0,
"runPostScan": 0
"runAs": 0,
"security": {
"authType": 1,
"expirationTime": {
"time": 0
"_type_": 15,
"userGroupId": 1,
"tagWithCompany": {
"providerId": 0
"sizeOnMedia": 6837977924,
"slaCategory": 11,
"slaCategoryDescription": "Excluded Server Type",
"slaStatus": 3,
"snapCopyInfo": {
"_type_": 5
"_type_": 3
"_type_": 3
"_type_": 110
"sqlUser": {},
"sshKey": {},
"sybaseUser": {},
"transportModeForVMWare": 0,
"storageDevice": {
"_type_": 17,
"_type_": 17
"networkAgents": 2,
"muxFactor": 0,
"perfCRCDetails": [
"perfMaId": 2
"perfClientName": "lol",
"softwareCompression": 2,
"throttleNetworkBandwidth": 0
"_type_": 65,
"turboNASClient": {
"_type_": 3
"subTaskId": 0,
"taskId": 0,
"userName": "0"
"dcPlanEntity": {},
"planEntity": {
"planId": 1,
"planName": "testing",
"planSubtype": 33554437,
"planType": 2
"proxyClient": {
"clientId": 2,
"clientName": "win-igicqf1affn"
"region": {},
"splunkProps": {},
"status": 0,
"_type_": 7,
"backupsetId": 8,
"clientId": 3,
"entityInfo": {
"companyId": 0,
"instanceId": 4,
"subclientId": 10,
"taPlanEntity": {},
"vmBackupInfo": {
"vmProtectedCount": 3,
"vmTotalCount": 3
"vmContent": {
"children": [
"allOrAnyChildren": true,
"displayName": "Ans_Jen_Pramod",
"equalsOrNotEquals": true,
"name": "52c0fb3f-9cf0-ea0c-6518-ff20a5d37a6f",
"path": "Ans_Jen_Pramod",
"type": 9
"description": "",
"displayName": "Ans_Jenkins_Vishak",
"name": "503be9bc-b6ba-e09b-333d-dc0484a5c9d0",
"path": "Ans_Jenkins_Vishak",
"type": 9
"vmDiskFilter": {},
"vmFilter": {},
"vmSLAInfo": {
"vmExcludedCount": 0,
"vmMetSLACount": 3,
"vmMissedSLACount": 0
"autoDetectVMOwner": false,
"amazonClient": {}
"proxies": {},
"proxyESXServer": {
"vsInstance": {
"clientId": 3,
"instanceId": 4,
"quiesceGuestFileSystemAndApplications": true,
"useChangedTrackingOnVM": true,
"useVMCheckpointSetting": true,
"vendorType": 1,
"virtualServerRetention": {
"retentionOverride": false,
"snapCopiesToRetain": 3
  • May 29, 2024
"_type_": 7,
"backupsetId": 8,
"clientId": 3,
"entityInfo": {
"companyId": 0,
"instanceId": 4,
"subclientId": 10,
"_type_": 7,
"backupsetId": 12,
"clientId": 8,
"entityInfo": {
"companyId": 0,
"instanceId": 2,
"subclientId": 14,
