VM backup automation
  • April 10, 2025
  • 82 views
Forum|alt.badge.img+13
Hi Team,
I am trying to do an automation. As part of this, I want to add a VM that I have pulled as a variable via a form to a subclient first (if the subclient content is full, it will clean it and then add the VM) and I want to trigger the Full backup of the relevant subclient. Which Rest API, qcommand, commvault powershell module etc. can I do this better with and which API or commands can I do it with, can you give me some guidance?
Another question is, how can I start the Full backup of a VM that I have pulled as a variable via a form (a VM that I have never backed up before, that Commvault does not know yet)?
Hello ​@0ber0n
Adding a new VM into a subclient:
https://api.commvault.com/docs/SP36/api/cv/VirtualizationOperations/update-subclient-virtual-machine-content/
Running a backup through API on a VM:
https://api.commvault.com/docs/SP36/api/cv/VirtualizationOperations/perform-vm-backup/
I hope this answers your questions!
Kind regards
Albert Williams
Hello ​@0ber0n
Kind regards
Albert Williams
