Hi
Does anyone know if there are any restrictions in the workflow engine regarding the use of temporary tables in the CommservDBQuery activity? In the SSMS the query works fine.
When I run the above SQL query in the debug mode, I donโt get any output:
I also tried to use a table as variable, which did not work either.
The workflow engine runs on a dedicated server. Could this cause the issue?
Thanks for your inputs
Michael
