Workflow Engine Execution step
  • May 31, 2022
  • 135 views
Hello Folks,
I have to perform these three steps via WF but I can't find any guide that I can help myself.
Anyone have experience?
Backup of Server AMI (AWS)
Then
Backup FS via Media Agent
Then
SQL Backup FULL / Differential Online
Best regards,
xor
Best answer by Gseibak
Hi xor,
there are a few pre-defined workflows you should see in the GUI.
one in particular is called “File System Backup Restore” - you can just clone it and remove the restore part.
Also, if you walk through the actual restore in the GUI you can save that as a script which creates the XML and the XML and be re-used in the backup activity for any workflow. - https://documentation.commvault.com/11.24/expert/45435_save_as_script_overview.html
we also have backup related workflows in the store to reference - https://cloud.commvault.com/webconsole/softwarestore/#!/136/677?fl=%7B%22keyword%22:%22backup%22%7D.
  • May 31, 2022
Hi xor,
  • May 31, 2022
Roger!
Xor
