Add S3 compatible Cloud Library using Python or REST API
  • 4 May 2023
  • 64 views
Badge +5
  • Commvault Certified Expert
  • 17 replies
I want to automate the creation/adding of new libraries, specifically such of the type “S3 compatible”. So, not a classical Disc Library and neither a Cloud Library (Like Azure or AWS).
I’ve crawled through the Python Modules and the REST API but I can’t seem to find any way of adding such “S3 compatible” type library, only normal Disc or Cloud ones.
Does anyone know of a way to get this done? Or have I missed something?
Best answer by Onno van den Berg 4 May 2023, 23:04
Badge +19
Hi @ChrisK!
Please try to add the library via Command Center! The config page contains an option to display the API payload see the picture below.
