Commvault API to get DDB Engine Dependent Copy Information
  • July 11, 2022
  • 87 views
Hello Team,
Is there a way to get the DDB Engine dependent copy information through REST API? I am specifically looking for information that is available in Java console:
Storage Resources > Deduplication Engines > DDB_ENGINE_NAME > Dependent Copy Information.
Abdul
Best answer by Mike Struening
@AbdulWajid , you’re likely better off using the APIs to pull this data; we just need to find the right one.
Not sure if you checked out our API library here (link to the ddbinformation call):
https://api.commvault.com/#8b5aec79-1cf0-42d3-87f3-b70a553a3994
There are several options underneath the Storage Policy section that should help:
https://api.commvault.com/#e0ad9c70-ecb4-4d1f-aa2a-f135eff98fc0
If there’s something specific you don’t see, let me know and I’ll reach out to some devs.
  • July 11, 2022
See if this one helps
https://documentation.commvault.com/v11/essential/124230_rest_api_get_deduplication_database_details.html
storagePolicyName
The name of the storage policy.
storagePolicy
storagePolicyId
The system-generated ID of the storage policy.
storagePolicy
It should list the SP against DDB but not 100% sure it will list all the dependent ones.
  • July 11, 2022
storagePolicyName
storagePolicy
storagePolicyId
storagePolicy
Thanks Jordan. Unfortunately this does not provide the details that I am looking for. I see there is also an option to run qcommands. Is there a way to get the information that I am looking for through qcommands?
