DR Backup Post Process unable to run Powershell script ?
  • 10 February 2023
  • 85 views
Badge +7
Hi!
We’re currently running a .bat script to do some simple copying of files to another destination, and we’re in the process of updating this to a powershell script, that basicly does the same, but does some additional checks and such first.
I’ve verified that i can run the script manually with when i’m logged in as the user specified in the “run as user”
But when i run a disaster recovery backup, i get the followig error:
Error Code: [7:78] Description: Unable to run [C:\Path_to_Script\Name-of-script.ps1] on the client. Internal Error [150995005] in CVSession while communicating with remote host [Remote system [FQDN of Commcell server]. Remote execute request returned error: [].]. [] Source: commcellserver, Process: startPrePostCmd
Anyone know what could be the issue here ? As far as i can see/understand, there should not be any “Remote System” ?
Badge +14
If you look in the log “startprepostcommand.log” on the CommServe, do you see more details on the issue than in Job Manager?
Badge +7
Not really any more details ….. here is an example of one of the attempts (logs sanetized somewhat):
12956 3110  02/10 13:11:05 ####### ::main() - jobId 1530185 - commandPath = <Path-to-Script>\PSscript.ps1
12956 3110  02/10 13:11:05 1530185 ::main() - jobId 1530185 userImpersonationLevel[2] - before execute cmd
12956 3110  02/10 13:11:05 1530185 ::main() - jobId 1530185 - Use Impersonation.
12956 3110  02/10 13:11:05 1530185 ::main() - jobId 1530185 - Got username [Domain\<ServiceAccount>]
12956 3110  02/10 13:11:05 1530185 ::main() - jobId 1530185 - remoteexename = [<Path-to-Script>\PSscript.ps1]
12956 3110  02/10 13:11:05 1530185 ::main() - jobId 1530185 - args = [ -bkplevel 1 -attempt 5 -status 1 -job 1530185]
12956 3110  02/10 13:11:05 1530185 executePrePostCmd() -  Attempting to execute remote command on client [<Commserve>]..
12956 3110  02/10 13:11:06 1530185 executePrePostCmd() - jobId 1530185 - Error encountered in ExecRemoteCmdAndWait - [0x80070306:{CCvNetwork::ExecRemoteCmdAndWait(2740)} + {CCvNetwork::ExecRemoteCmdAndWait(2721)/W32.774.(One or more errors occurred while processing the request. (ERROR_ERRORS_ENCOUNTERED.774))-}]
12956 3110  02/10 13:11:06 1530185 executePrePostCmd() - jobId 1530185 - Received error text from remote cvsession [Internal Error [150995005] in CVSession while communicating with remote host [Remote system [<Commserve>.<Domain>]. Remote execute request returned error: [].].  []]
12956 3110  02/10 13:11:06 1530185 executePrePostCmd() - jobId 1530185 - Error [9000056] returned from executeRemoteCommand <Path-to-Script>\PSscript.ps1
12956 3110  02/10 13:11:06 1530185 EvEvent::setMsgEventArguments() - MsgId[0x0700004e], Arg[1] = [117440623]
12956 3110  02/10 13:11:06 1530185 EvEvent::setMsgEventArguments() - MsgId[0x0700004e], Arg[2] = [<Path-to-Script>\PSscript.ps1]
12956 3110  02/10 13:11:06 1530185 EvEvent::setMsgEventArguments() - MsgId[0x0700004e], Arg[3] = [Internal Error [150995005] in CVSession while communicating with remote host [Remote system [<Commserve>.<Domain>]. Remote execute request returned error: [].].  []]
12956 3110  02/10 13:11:06 1530185 EvEvent::setMsgEventArguments() - [MsgId[0x0700004e][]: [3] Args Pushed, [1] Args expected.
12956 3110  02/10 13:11:06 1530185 ::exitHere() - jobId 1530185 - Exiting due to failure.
