Workflow - CommServDBQuery cannot use temp tables?
  • 19 September 2023
  • 23 views
Badge +1
Hi
Does anyone know if there are any restrictions in the workflow engine regarding the use of temporary tables in the CommservDBQuery activity? In the SSMS the query works fine.
When I run the above SQL query in the debug mode, I don’t get any output:
I also tried to use a table as variable, which did not work either.
The workflow engine runs on a dedicated server. Could this cause the issue?
Thanks for your inputs
Michael
Best answer by Yeshwanth 20 September 2023, 09:01
Badge +2
Hi @Michael.B ,
Can you add SET NOCOUNT ON at the beginning?
You can refer to documentation here -
https://documentation.commvault.com/commvault/v11_sp20/article?p=49839.htm
Yeshwantth
Badge +1
HI Yeshwantth
Perfect thanks, that works.
Regards
Michael
