Is grouping 24 SQL Instances together possible?
  • Jun 17, 2024 6:15 AM UTC
  • 43 views
Forum|alt.badge.img+5
We have a use case scenario to take backup of 24 SQL instances via command center.
Is there a way we can group them together so that a single backup can group those SQL Instances together in one go?
Hello @Jass Gill ,
you can create 1 schedule ( RPO) and associate it to each of these instances but you cannot have them all run under the same job. This will make them all run at the same time in their own job.
Kind regards
Albert Williams
