Can we add 7 HPE apollo nodes initially in hyperscale X
  • Mar 8, 2024 10:52 AM UTC
  • 67 views
Can we add 7 HPE apollo nodes initially in hyperscale X and do the initial installation and bring up the configuration OR should it be i start with 3 nodes first and complete the set up and installation initially and then add rest of the 4 nodes one by one ?
i see below information in documentation.
R Anwar
  • Mar 10, 2024 11:50 AM UTC
Hi @Noushad
You can setup all nodes using hsxsetup and create a single Storage Pool. Kindly use the new HSX 3.x. ISO.
Also, share the link where you see the above mentioned information.
  • Mar 12, 2024 8:38 AM UTC
@R Anwar
Thank you for the response.
Below is link to above screenshot,
https://documentation.commvault.com/2023e/expert/hyperscale_x_reference_architecture.html
So this means i can install HSX in all my 7 HPE Apollo nodes together in one go right ?
can you please help to confirm if my existing commserv is at 11.32.42, then is it supported for Apollo 4200 Gen10 ?
