We seem to run into multiple problems in our new HSX environment. Metadata disk d2 silently filled 100% on one of three nodes, data disks are all 90-95%, but in GUI only 550 of 720TB are shown as used. Not a single alert for this, all green in GUI.
An then there is disk d22 / sdv on one node that failed a few weeks ago and was replaced together with support. In GUI it’s shown as mounted but in reality its not.
sdu 65:64 0 16.4T 0 disk /hedvig/d21
sdv 65:80 0 16.4T 0 disk
sdw 65:96 0 16.4T 0 disk /hedvig/d23
I followed Replacing Disks in an HyperScale X Reference Architecture Node (commvault.com) but the disk is not mounted.
Nov 9 11:22:38 sdes1701-dp systemd: Dependency failed for /hedvig/d22. Nov 9 11:22:38 sdes1701-dp systemd: Job hedvig-d22.mount/start failed with result 'dependency'. Nov 9 11:22:38 sdes1701-dp systemd: Job dev-disk-by\x2duuid-dfcc3e6c\x2d8152\x2d42b2\x2db0a1\x2d6742d4748d3c.device/start failed with result 'timeout'.
Any idea what to do until support calls me?
