hsxsetup issue
  • Jan 9, 2025 8:22 PM UTC
  • 7 replies
  • 166 views
Hello all
please can you help with this issue there the A nad PTR records exists ?
Thanks Pavel
  • Jan 9, 2025 8:27 PM UTC
changed to xxx.local
the same for all nodes
root@hsx2 ~]# nslookup
> 192.168.166.74
74.166.168.192.in-addr.arpa     name = hsx1.ixxx.local
> 192.168.166.75
75.166.168.192.in-addr.arpa     name = hsx2.xxx.local
> 192.168.166.76
76.166.168.192.in-addr.arpa     name = hsx3.xxx.local
[root@hsx2 ~]# hostnamectl status | grep 'Static hostname' | awk '{print $3}'
hsx2.xxx.local
/var/log/commvault/Log_Files/cvinstall_hsxavahi.log
19460 140430382283648 2025-01-09 14:42:05,767 ERROR    Invalid IPv6 address [192.168.166.74]
19460 140430382283648 2025-01-09 14:42:05,767 ERROR    Invalid IPv6 information : IPaddr [192.168.166.74] Intx [] SerialNum [6hvtw64]. Checking if this is IPv4.
19460 140430382283648 2025-01-09 14:42:05,767          Using [192.168.166.74] for communication
19460 140430382283648 2025-01-09 14:42:05,847          Executing command on remote node: hostnamectl status | grep 'Static hostname' | awk '{print $3}'
19460 140430382283648 2025-01-09 14:42:06,072          Remote command execution stdout - [hsx1.xxx.local
19460 140430382283648 2025-01-09 14:42:06,073          Successfully obtained hostname from remote node [6hvtw64] - value [hsx1.xxx.local]
19460 140430382283648 2025-01-09 14:42:06,076          Remote node: 192.168.166.75
19460 140430382283648 2025-01-09 14:42:06,076 ERROR    Invalid IPv6 address [192.168.166.75]
19460 140430382283648 2025-01-09 14:42:06,076 ERROR    Invalid IPv6 information : IPaddr [192.168.166.75] Intx [] SerialNum [8hvtw64]. Checking if this is IPv4.
19460 140430382283648 2025-01-09 14:42:06,076          Using [192.168.166.75] for communication
19460 140430382283648 2025-01-09 14:42:06,156          Executing command on remote node: hostnamectl status | grep 'Static hostname' | awk '{print $3}'
19460 140430382283648 2025-01-09 14:42:06,364          Remote command execution stdout - [hsx2.xxx.local
19460 140430382283648 2025-01-09 14:42:06,364          Successfully obtained hostname from remote node [8hvtw64] - value [hsx2.xxx.local]
19496 140223681284992 2025-01-09 14:42:06,533          Argument [command_line_kwargs] : [{}]
19496 140223681284992 2025-01-09 14:42:06,533          Argument [hostnames] : [['jhvtw64', '6hvtw64', '8hvtw64']]
19496 140223681284992 2025-01-09 14:42:06,533          Argument [subcmd] : [getnwconfig]
19496 140223681284992 2025-01-09 14:42:06,533          Get NW configuration files from given hosts..
19496 140223681284992 2025-01-09 14:42:06,533          ['jhvtw64', '6hvtw64', '8hvtw64']
19496 140223681284992 2025-01-09 14:42:08,372          Copying file [/opt/commvault/MediaAgent64/Temp/HsInstaller/nwconfig/8hvtw64_getnwconfig.json] from node [hsx2.xxx.local]
19496 140223681284992 2025-01-09 14:42:08,470          NW configuration obtained from host hsx2.xxx.local saved in file /opt/commvault/MediaAgent64/Temp/HsInstaller/nwconfig/8hvtw64_getnwconfig.json
19730 139684921711488 2025-01-09 14:43:00,352          Argument [command_line_kwargs] : [{}]
19730 139684921711488 2025-01-09 14:43:00,352          Argument [filename] : [/opt/commvault/MediaAgent64/Temp/HsInstaller/avahibrowse.ini]
19730 139684921711488 2025-01-09 14:43:00,352          Argument [ips] : []
19730 139684921711488 2025-01-09 14:43:00,352          Argument [subcmd] : [discover]
19730 139684921711488 2025-01-09 14:43:00,353          Discover nodes with Installer Avahi Service.
19730 139684921711488 2025-01-09 14:43:00,353          Discover try #0
19730 139684555577088 2025-01-09 14:43:01,360          Service Discovery returncode = 0
19730 139684921711488 2025-01-09 14:43:01,360          self.browse_process.returncode = 0
19730 139684921711488 2025-01-09 14:43:01,361          Got avahi-browse output
19730 139684921711488 2025-01-09 14:43:01,367          Update hostnames for nodes where NW is already configured
19730 139684921711488 2025-01-09 14:43:01,372          Local node: fe80::aeb4:80ff:fe26:3669
19730 139684921711488 2025-01-09 14:43:01,372          Executing command on local node: hostnamectl status | grep 'Static hostname' | awk '{print $3}'
19730 139684921711488 2025-01-09 14:43:01,507          Local command execution stdout - [hsx3.xxx.local]
19730 139684921711488 2025-01-09 14:43:01,508          Successfully obtained hostname from remote node [jhvtw64] - value [hsx3.xxx.local
  • Jan 9, 2025 8:30 PM UTC
changed to abc.local
nslookup for all nodes the same
[root@hsx3 ~]# nslookup
> 192.168.166.74
74.166.168.192.in-addr.arpa     name = hsx1.abc.local
> 192.168.166.75
75.166.168.192.in-addr.arpa     name = hsx2.abc.local
> 192.168.166.76
76.166.168.192.in-addr.arpa     name = hsx3.abc.local
  • Jan 9, 2025 8:31 PM UTC
hsx2.abc.local
R Anwar
  • Jan 10, 2025 7:30 AM UTC
Hi ​@Pavel Banar
After changing the hostname, I would recommend restarting avahi services(systemctl restart avahi) and run hsxsetup on all nodes again before doing on last node.
  • Jan 10, 2025 11:45 AM UTC
Hi Hi
yes server was restatred, cat /etc/hostname shows correct hsx1.abc.local (hsx2,hsx3)
Pavel
  • Jan 10, 2025 11:49 AM UTC
HI R Anwar , maybe we are on right way
[root@hsx1 ~]# avahi-resolve -a 192.168.166.74
Failed to resolve address '192.168.166.74': Timeout reached
[root@hsx1 ~]# nslookup 192.168.166.74
R Anwar
  • Jan 15, 2025 9:33 AM UTC
Hi ​@Pavel Banar
Please check the file /etc/avahi/services/cvlt.service. It’s is definitely something on the avahi side failing to resolve the hostname so could need a minute tuning.
