Using the hyperscale X as access node for CIFS backups
  • November 25, 2025
  • 101 views
I’m trying to back up Netapp CIFS share with the Hyperscale as access node
The hyperScale have  11.36 with ISO 3.2506
I cant choose the HSX as access node while browsing the content and the back up failed with
“Failed to mount file share volume“
the HSX has cifs-utils installed and samba-client installed
AM I missing someting that is required for CIFS backup with Hyperscale X as access node?
Bronco
  • November 25, 2025
Hello LiorRN,
HyperScale X nodes cannot be used as NAS Access Nodes because the HSX operating image does not include the Commvault NAS package required for CIFS/NFS traversal, and therefore CIFS shares cannot be mounted or enumerated on HSX
1. HyperScale X nodes cannot be used as NAS (CIFS/NFS) Access Nodes. HSX OS image does not include the NAS package, and therefore cannot perform SMB/CIFS scanning or mounting required for NetApp CIFS backups.
2. Even if "cifs-utils" and "samba-client" are installed, HSX still lacks the Commvault NAS components. The HSX ISO excludes:
==>  NAS Package
==>  NAS Helper Modules
==>  FUSE-based NAS scanning libraries
==>  Required Python modules for NAS traversal
3. Therefore HSX nodes will not selectable Access Nodes for NetApp CIFS shares. This is expected and documented Commvault behavior.
4. CIFS backups require a supported Access Node with NAS package installed.
Official supported types:
==>  Windows File System Agent (recommended)
==>  Linux Access Node with NAS Package (Non-HSX Linux only)
5. As a solution, deploy a separate Windows or Linux Access Node and assign it to the NetApp CIFS client.
Siddharth Gandhi
  • November 27, 2025
thanks
