Hi There
Currently doing the “SaaS Specialist PLUS for MSPs” learning path, and I’ve finished all but one subject.
That is “SaaS Specialist - Active Directory and Azure Active Directory - 2022”.
“You cannot access the course because it is under maintenance”
It’s been like this all week, and its the only subject I have left on it.
Is there anymore information or update on when this will be available????
