Endpoint backup plan and RPO
Forum|alt.badge.img+5
  • Byte
  • 15 replies
Hi
On endpoint backup plan there is option “RPO” under backup frequency is every 4 hrs. this every 4 hrs. is full backup, incremental or differential, and is there any way we can confirm the backup running every 4 hrs. is full, incr. or diff.
Best answer by Ryan Carr
Hi Aju
The first job will be as full and subsequent jobs appear to be incremental
you can view this via the laptop section. Select a laptop and view jobs to view the history
In the next window use the columns feature and select Backup type. this will show you the job history and backup type
Let me know if this helps
Ryan
Ryan Carr
  • 24 replies
  • July 12, 2022
Hi Aju
Ryan
  • Byte
  • 15 replies
  • July 13, 2022
Hi
Thank you for your response, so first job fill be full and subsequent jobs will be incremental, does it mean only one job will be full and rest of all jobs may be run for next one year will be incremental jobs
Ryan Carr
  • 24 replies
  • July 13, 2022
Hi Aju
Yes exactly that. The change rate of data in laptops tends to be minimal. Most users tend to just add or remove documents so incremental would be the most optimal way to manage endpoint backups
Onno van den Berg
Commvault Certified Expert
First job will be a full and from there is will create incremental backups combined with synthetic full backups who are created every 30 days, if I recall this correctly. A synthetic full is basically a full that is constructed on the backend leveraging the previous full and all following incrementals.
Cookie policy
Cookie settings
