HSX nodes can be used for MCSS library with deduplication enabled
  • April 25, 2022
  • 64 views
Ananth
Hello All,
I have 3 node HSX cluster, Am I allowed to use the HSX nodes as source and destination media agent for MCSS cloud library?
while creating MCSS library, If I am choosing three HSX nodes for the MCSS and when i enable deduplication where my ddb will be hosted on the HSX nodes?
Regards
Ananth
Best answer by Ronnie Kaftal
Hi
Yes, HSX nodes  can be used as the MA feeding data to MCSS or any cloud library.
There should be enough space on the DDB partition to host a secondary DDB for cloud library.
Please follow the add metallic cloud storage guide on docs.commvault.com
https://documentation.commvault.com/11.24/essential/131164_getting_started_with_metallic_cloud_storage.html
Ronnie Kaftal
  • April 25, 2022
Hi
