Min Upload Speed for Metallic
  • March 4, 2022
  • 149 views
is there a minimum network upload speed for a metallic endpoint ?
regards,
Markus
Best answer by Kalyani
Hi Bischi, here is my take on this,  we don’t have any minimum required bandwidth as long as upload requests won’t get timed out, backups should run fine. Based on bandwidth backup may take longer to finish.
Hi @Bischi !  Thanks for the post!  I’m not aware of any specific limitation, though I inquired on your behalf earlier this morning with our product managers.
Are you encountering any issues that made you ask?
  • March 4, 2022
Hi Mike,
yes, I have a customer who has a very slow internet connection with average download speed of 23.2 Mbit/s and an average upload speed of 8.5Mbit/s. I do encounter a problem in the stability of the backup.
regards,
Markus
  • March 7, 2022
  • March 7, 2022
Many thanks Kalyani,
I will give it another try when I’m at the customer.
regards,
Markus
