[24:64] Description: There was nothing to restore - subclient(s) not backed up. Help!
  • April 11, 2022
  • 1108 views
I'm getting the error [24:64] Description: There was nothing to restore - subclient(s) not backed up.
When I do the restore of the virtual machine the restore works normally, but when I restore the guest files and folder, the commvault shows this error.
I can also browse the files normally, does anyone have any idea what might be going on? restores are for Nutanix AHV.
Best answer by Mike Struening
Looks like you opened a case for this and found the issue (and if I’m looking at the wrong incident, let me know):
I did a restore now forcing the Copy precedence and it worked, the file was restored successfully.
  • April 12, 2022
Can you try browse from a backup job and from a subclient/VM group(latest browse) to check if it gives same error ?
  • April 13, 2022
Hi @Sana !
Yes, I can browse without errors and see files normally by job and subclient (VM).
  • April 26, 2022
Please open a support case to check this further. Thanks!
