Accessing Comcell Console
  • January 12, 2022
  • 4318 views
Curious if there’s a better way for users with specific roles to access the Commcell other than  the CommVault Simpana.jnlp.  I downloaded/extracted netx.jar and it opened to the Commcell a couple times, then failed.  Thx!
Best answer by Amey Karandikar
Can you try the latest version of netx.jar?
https://cloud.commvault.com/webconsole/softwarestore/#!/96/711/12233
dude
Forum|alt.badge.img+20
  • Community All Star
  • January 12, 2022
  • January 13, 2022
We still receive the error message when downloading the galaxy.jnlp file - This type of file can harm your computer.  Do you want to keep the galaxy.jnlp anyway?  & an unsecure connection is established to the console.  Is there any other “secure connection” option (IE: html5)?
dude
  • January 13, 2022
The link I sent you above is for accesing the adminconsole via HTML5 based access.
https://webserverhost/adminconsole/
  • January 13, 2022
Install the native Windows Commcell Console app on your desktop. It is a lot faster and more reliable than the Java app.  Assuming you use Windows of course.
Forum|alt.badge.img+8
