Activate Data Governance - Confirm Reviewing (SAR)
  • July 27, 2022
  • 47 views
Hi all,
after reviewing and accepted or denied all documents present in a request, the status of the documents is not updated.
Only after several attempts to move between the tabs of activate, it updates and I see the "complete review" or "request approval" access keys appear.
The currently installed version is 11.28.10
Best answer by Mike Struening
@Gabriele Palumbo I am assuming this is now working.
If not, I would check which browser you are using.  I’m not aware of this issue, though it could be an older browser causing a delay, or temporary internet files, cached files, etc.
@Gabriele Palumbo , can you repaste those images?  They are not showing up.
I spoke to the team Associate Managers for this topic who suggested opening a support case.  they have yet to see this.
Can you share the case number once you do?
@Gabriele Palumbo , following up on this one.  Were you able to get a case created/solve the issue?
@Gabriele Palumbo , can you confirm if this issue is still occurring?  I don’t see a case in your name.
  • September 12, 2022
