Add MA to CommCell
  • September 11, 2021
  • 368 views
Fernando Souza
Byte
Forum|alt.badge.img+13
Hello
I have a doubt:
I have to add a MA server (RX2540 M5) to Commvault, the best way to add is by Commvault(CommCell) or do I do it through the Commvault software on the machine(rx2540)?
So, do I have to create the MA database on the server or not?
@Mike Struening
Best answer by Laurent
So, from this image, you talk about the MediaAgent database, and not the Commserve database.
Just to be 100% sure, you Commserve role is held by a different server than your MediaAgent : correct ?
Also, next question : do you want to add MediaAgents for a brand new storage policy, or add mediagents to an existing set of MediaAgents and storage policy -gridstor ?
Although in almost any case, I would recommend you to install them ‘manually’ by RDP (windows) or SSH (linux).
Chris Hollis
  • 333 replies
  • September 13, 2021
Hi @Fernando Souza
There is no right or wrong way, it’s a personal preference.
Installation methods are here: https://documentation.commvault.com/commvault/v11_sp20/article?p=1969.htm
E.G. If you want to push from the console, follow these instructions: https://documentation.commvault.com/commvault/v11_sp20/article?p=1977.htm
If you want to install locally, refer to: https://documentation.commvault.com/commvault/v11_sp20/article?p=2005.htm
Hopefully this helps,
Chris
  • Byte
  • 386 replies
Hi @Fernando Souza ,
I prefer to deploy it manually, this allows me to make sure that all the install steps have been performed properly : it’s a bit faster for troubleshooting, if needed.
What do you mean by Database ? The deduplication database ? Or the Commserve database, meaning you want to perform a hardware refresh of some existing Commserve that also is a Media Agent ?
Maybe Mike is aware of your environment and knows, but from this reading, I can’t tell :wink: Can you detail a bit more please ?
Fernando Souza
Byte
Hello @Laurent
I'm referring to the Media Agent Server database.
  • Byte
  • 386 replies
Fernando Souza
Byte
@Laurent
Yes, i added MA by CommServ, not by server, and create the storage polices, DDBs, Disk library, Mount Paths, and did replication and made changes.
The server is MS Windows
Many thanks.
Cookie policy
Cookie settings
