After change any dashboard his not work
  • June 1, 2022
  • 13 replies
  • 1250 views
Forum|alt.badge.img+2
After I made changes to any standard dashboard(ex: /commandcenter/#/dashboard/commcell) - it becomes inaccessible: “Something went wrong. Server may be under maintenance.”
The same if I create a clone of the current one.
How to fix or reset dashboards to default?
Best answer by Leonid
MR27 fixIt
all THX!
  • June 1, 2022
@Leonid
  1. Stop Commvault Tomcat service
  1. Did a restart IIS, At the command prompt, type IISRESET.
  2. Start Commvault Tomcat
  3. Revert to default https://documentation.commvault.com/11.24/essential/129158_reverting_changes_to_default_dashboard_on_command_center.html
  • June 1, 2022
restarts and update MR25 to MR26 not helpme..
go try to revert defaults..
  • June 1, 2022
no revert plan is done - i cannot found this button
  • June 1, 2022
When checking the WebServerCore component, http://localhost:81/WebServerCore an error occurs:
The .NET folder under Program Files was missing the dotnet.exe binary.
.NET Core 2.1 uninstalled, a fresh installer downloaded from Microsoft Download .NET Core 2.1 and reinstalled.
IIS and Tomcat restarted, WebConsole is now up and running.
  • June 1, 2022
11.26.26 use .NET Core 3 , i update it up to 3.1.25 - no effect.
HTTP Error 404.0 - Not Found
The resource you are looking for has been removed, had its name changed, or is temporarily unavailable.
  • June 1, 2022
it is problem only for changed dashboards!
This dashboard i no change and it work!
  • June 2, 2022
@Dmitriy only clone dashboard(w/o edit) not open
master role dont help
  • June 3, 2022
Hello Leonid,
FR 26 > MR27 has a fix for this issue.
Venkat
  • June 3, 2022
next problem - i cannot download any fix(
Error Code: [68:472]
Description: Download is skipped for [SP26_4050133:UP26_0] because the media is not available for it.
@Leonid , call support and mention this thread.  They should be able to request access on your behalf.
  • June 10, 2022
MR27 fixIt
all THX!
Thanks for the update @Leonid !!
  • December 6, 2023
@Leonid
step 1-3 worked for me
