Alert: Threat Indicator
  • May 30, 2025
  • 185 views
Forum|alt.badge.img+8
All,
I have the Threat Indicator alert enabled on my Commserve.
I have a VSA backup that runs nightly and every evening it picks the same folder and flags it in Monitoring → Threat indicators in the Command Centre and it emails this alert to all.
The particular folder it mentions every night runs some DBA scripts that are scheduled.
Is there anyway to remove this files ie E;\DBA_Scrits or this VM from the Threat Indicator alert ?
There is nowhere to edit on the Alert in the CommServe, I found the workflow below and ran it but still got an alert the following morning.
  • June 4, 2025
anybody?
Rajiv
  • June 6, 2025
Hi ​@atitagain
To remove the files in the E:\DBA_Scripts directory from being flagged in the Threat Indicator alert, you can add an additional setting to exclude the specific path or file types.
Here are the steps you can follow:
  1. Log into the Command Center.
  2. Navigate to Manage > System > Settings.
  3. Add the additional setting sAnomalyFilters to exclude the path or file types that are causing the false positives.
For more information on excluding specific paths or file types, you can refer to the Additional Setting: sAnomalyFilters
Best,
Rajiv Singal
Onno van den Berg
Hi ​@atitagain
Best,
Rajiv Singal
Are you sure this key works for Threat Indicator alerts who are triggered as a result of VSA level file indexing? The key is applied on category FileSystemAgent.
