I want to set a storage policy (a plan actually) for Oracle backups. The only thing is customer wants to just provide storage target for RMAN backups but leave actual backup administration in hands of Oracle admins. Oracle team won’t have access to Commvault console, so they need to manage backups with the only tool they know and got which is RMAN. Everything is set, we got plan in place, activity on default and archivelog subclients is disabled, so Commvault won’t run any backups (a plan without scheduler would be nice!), we did some tests and backups work like a charm and the only missing part is data aging. For this setup to work nicely and to give Oracle team what’s theirs I also need to allow them to prune old backups using RMAN so I could set infinite retention on Commvault side (currently it’s 14 days). I’ve set DisableRMANPruning to 0 on Commserve computer and crossed my fingers but unfortunately it is not enough. After running a couple of backups using RMAN command line we can see that RMAN is removing obsolete backup pieces just fine, however nothing has been aged from the Commvault side. RMAN redundancy is set to 1, so after successful backup I should have 1 job in storage policy copy, but currently I have 10.
Any ideas if I missed something or is there any other Additional settings I should set?
Summary
Commserve\Additional Settings\DisableRMANPruning = 0
RMAN redundancy = 1
Retention on storage policy copy = 14 days
CS Additional settings:
https://documentation.commvault.com/additionalsetting/details?name=%22DisableRMANPruning%22&id=2475
RMAN log fragment:
Finished backup at 18-AUG-22
RMAN retention policy will be applied to the command
RMAN retention policy is set to redundancy 1
Deleting the following obsolete backups and copies:
Type Key Completion Time Filename/Handle
Backup Set 3499 18-AUG-22
Backup Piece 3499 18-AUG-22 QTEST_DATABASE-18-20220818_dq15fsh4_1_1.BCP
Backup Set 3501 18-AUG-22
Backup Piece 3501 18-AUG-22 QTEST_CONTROLFILE-18-20220818_ds15fsp6_1_1.BCP
Backup Set 3502 18-AUG-22
Backup Piece 3502 18-AUG-22 QTEST_SPFILE-18-20220818_dt15fsp8_1_1.BCP
Backup Set 3504 18-AUG-22
Backup Piece 3504 18-AUG-22 QTEST_DATABASE-18-20220818_dv15fu27_1_1.BCP
deleted backup piece
backup piece handle=QTEST_DATABASE-18-20220818_dq15fsh4_1_1.BCP RECID=3499 STAMP=1113059876
backup piece handle=QTEST_CONTROLFILE-18-20220818_ds15fsp6_1_1.BCP RECID=3501 STAMP=1113060135
backup piece handle=QTEST_SPFILE-18-20220818_dt15fsp8_1_1.BCP RECID=3502 STAMP=1113060136
backup piece handle=QTEST_DATABASE-18-20220818_dv15fu27_1_1.BCP RECID=3504 STAMP=1113061448
Deleted 4 objects
released channel: ch1
Storage Policy copy jobs
Cheers,
Robert
