Autodesk BIM 360 platform integration with Commvault
  • October 8, 2021
  • 7 replies
  • 154 views
Hello Commvault Community,
Today I would like to ask you if Commvault has integration with the Autodesk BIM 360 platform?
I searched the available Commvault documentation but found nothing. My guess is it's not supported yet.
So, is there a workaround for this solution to be usable in a Commvault environment?
Thanks & Regards,
Kamil
Best answer by Mike Struening
@Ivan Shchetinin , @Kamil I spoke to our Products team who confirmed this is not currently being evaluated.
I would suggest contacting your Account Rep and discussing a possible commitment initiative.
Please let me know if you have any questions!
Hi @Kamil !  Thanks for the post!
I’m not seeing anything either in our docs.  Have you checked with the vendor to see if they have any scripted means to present the data to a file system?
Let me know if they have any advice and we can go from there.
Hey @Kamil , following up on this one.  Anything turn up via the vendor?
  • October 18, 2021
Hello @Mike Struening
Thanks for the help, however, the client stopped being involved in the integration of the Autodesk BIM 360 platform with Commvault.
We can consider the topic closed.
Thanks&Regards,
Kamil
Understood.  Thanks for the update!
For you or anyone else who has the same question, I can reopen this up!
Hello colleagues,
Can we please reopen the question. BIM 360 is a cloud platform by Autodesk. Data is stored in Autodesk's private cloud.
Is there any way we can backup it?
Reopened!
Let me ask internally if we have options.
