Automatically use optimal number of data readers not staying enabled
  • September 1, 2021
  • 277 views
Forum|alt.badge.img+9
Question: On a Windows cluster subclient when I change the performance setting to automatic use optimal number of readers and press ok it goes back to the Use data readers setting.
We are using Commvault version 11.23.12
Is this only going to be applied when we go to 11.24 ?
Hey @gary mcneely , I split this into its own thread so we can track it better.
I’ll discuss this with our Windows folks and get you an answer.
Hi @gary mcneely , I spoke to several people from several teams who are stumped and suggested opening a case with support so they could take a deep look.
Can you share the case number once you get one created?
