Azure DB SQl to onprem
  • January 17, 2025
  • 28 views
I try to configure backup for azure sql db to onprem.
Commvault version 11.36.28
I have an access node which can reach azure with open ports required.
My access node has following installed software :
When I run a job I received following error :
Could tell me what is wrong ?
Thank you
Best Regards
Patrick
Hello ​@patk
From the info you shared it appears that the export is not completing within Azure. You can see the DB copy is complete then the export begins does not complete. In the Azure portal for that db you can view the import/export history and will see an export at this same time. View to see if/why that is failing.
You can also confirm and test a native export to confirm the DB can be exported successfully.
https://learn.microsoft.com/en-us/azure/azure-sql/database/database-export?view=azuresql
