Backup Job Problem
  • June 18, 2021
  • 12 replies
  • 115 views
Fernando Souza
Novice
Problem in a Backup Job:
Does Someone know about this problem?
When the job started manually is OK, but when schedule dont run.
The backup job log file in attach.
Best answer by Mike Struening
Updating with the incident resolution.  Looks like there was a bad chunk in one of the required jobs.
Aplynx
  • June 18, 2021
What service pack is this running on?
Fernando Souza
Novice
11.21.15
@Fernando Souza , I spoke to @Aplynx and he suggested creating an incident.
Let me know the case number once you do!
Fernando Souza
Novice
ok @Mike Struening
i will create a tícket and pass the number to you.
Fernando Souza
Novice
@Mike Struening
Open case: IN-1760419
Let me know if you get a CV incident number (that is likely a partner case number).  I can search on the partner case number but only if it was supplied to us and entered :-(
MichaelCapon
Have you checked the Log Manager and IndexState logs on the MA at the times of the failure?
- check for the following GUID in those and let us know the results: DF8299F8-FFCF-434A-A722-87C1ABF09530
Michael
@Fernando Souza , I’m still not seeing that partner case number.  any chance you have a CV incident number (or a solution)?
Thanks!!
@Fernando Souza , following up again, I’m still not seeing that partner case number.  any chance you have a CV incident number (or a solution)?
Thanks!!
Fernando Souza
Novice
Hello @Mike Struening
WO: W667700493
Got it, thanks!!
