Best practice for Archiving NetApp SnapLock (WORM) volumes to WORM Tape Media
  • January 29, 2026
  • 236 views
Forum|alt.badge.img+18
Hi Commvault experts,
We are designing an archiving workflow and we’d like to get your advice on the best practices.
Let’s assume the source is NetaApp with SnapLock volumes (WORM) and target LTO tape library with WORM media.
Our goal is to move/archive data from NetApp SnapLock volumes to WORM tapes for long-term retention (10+ years).
What is the ideal storage policy for this setup? Does it make sense to use a “staging disk” as a Primary Copy and then a DASH copy to the tapes, or is there a better workflow for WORM volumes (primary copy directly to tapes)?
We are also choosing between two tape strategies. The first is a "Clean Archive" where data is written only once to save media. The second is "Periodic Fulls" where we write the full archive again every so often for better safety. Given that the source data is immutable, which approach do you recommend?
Your input will be much appraciated.
  • February 4, 2026
A DASH copy is deduplicated so it would not be relevant for an Aux Copy from disk to tape.  DASH would be possible with disk to disk. That said, you should be able to just Aux disk to tape here and be fine.
Have you looked into doing network share backups?  You could either write those directly to tape or just aux copy them to tape, either would work as well.
  • Challenger
  • February 5, 2026
Hi ​@Orazan, thank you for the clarification.
In that case, what is the recommended approach for archiving Netapp SnapLock (WORM) volumes to tapes?
Regarding network share backup - I found only how to add Network share backup, unfortunately, the more detailed explanation is not provided:
https://documentation.commvault.com/v11/commcell-console/add_network_share_backup.html
