Business logic workflow and Approver
  • Jul 1, 2024 2:27 PM UTC
  • 162 views
Hi together,
currently I am struggling with the business logic workflows.
Can the usergroup that authorizes a config change  and the aprovers group be the same … and Commvault takes care that not the same person authorizes the request?
Thank you.
Best regards.
Michael
Best answer by Jacek Piechucki
Yes, WF would be taking care about such situation. I believe there is one caveat: if there’s only one approver available, being the requestor at the same time, then the approvals get auto accepted.
Thank you very much. Yes, we have more than one user in the approver-group.
