I have created a powershell script using powershell sdk module to run multiple vm level backups which runs the backup but when i use the same powershelll script inside a workflow it doesnt work for some reason giving me message : I NFO: Get-CVClient: client not found having id [0].
Is there some limitation or something wrong the way i am passing the scrip inside workflow.
