Cli or script to Stop and start Commserve and MA Services
palcode
Bit
Forum|alt.badge.img+2
Hi, have anyone made a script or used cli commands to control the procedure of shutting down an entire commserve environment in windows.
I suppose you can do most of the stopping services with windows powershell , but how to disable all activity in commserve.
Best answer by Tomas
for stopping and disabling services you can use:
GxAdmin.exe -consoleMode -stopsvcgrp All -disable -timeout 60
but before doing this on MAs, I would recommend to disable MAs on Commvault level before, and ensure no jobs using these MAs are running:
qoperation execscript -sn setMediaAgentProperty -si sample_ma -si 9 -si 0
Hi @palcode
Thanks for the question, we have lots of command line capability in Documentation:
Command Line
Specifically, to disable activities at Commcell level, you need this command:
Disabling Activities at the CommCell Level Using the Command Line Interface
Stuart
  • Byte
  • March 24, 2021
Forum|alt.badge.img+23
Surendra Nadh Arla
I could not find the timeout value anywhere in our documentation, all our console timeouts are defined in seconds, It might be the same here.
Surendra Nadh Arla
Hi Palcode,
You can find the CLI command for disable/enable activity in the below link.
https://documentation.commvault.com/11.21/expert/133379_disabling_activities_at_commcell_level_using_command_line_interface.html
Surendra Nadh Arla
You can automate both the tasks in workflow automation as well if you have basic knowledge on Workflows
Cookie policy
Cookie settings
