Client Index error
  • October 22, 2021
  • 1620 views
Henke
Novice
Since some time I’m seeing this error in an alert from one client server.
Looked around but didn’t find a way to fix this. Anyone have any idea or do I need to get with support to fix it?
//Henke
12512 216c  10/10 20:01:51 ### DB [022F35E5-161D-4D28-A9E4-5549603A2F00] - Engine [1] Status [IDX_DB_ERROR] - Reason [Playback failed for job 43940. Error: Unknown error, Can't process log for job id [43940] can't get imageId for it. Rejecting it for playback  (ErrNo.1001)]
12512 830   10/10 20:01:52 ### DB [022F35E5-161D-4D28-A9E4-5549603A2F00] - Engine [1] Status [IDX_DB_ERROR] - Reason [Playback failed for job 43940. Error: Unknown error, Can't process log for job id [43940] can't get imageId for it. Rejecting it for playback  (ErrNo.1001)]
12512 2264  10/10 20:04:47 ### DB [022F35E5-161D-4D28-A9E4-5549603A2F00] - Engine [1] - Status [IDX_DB_RECONSTRUCTION] - ReconJobcount [1]
12512 105c  10/10 20:04:47 ### DB [022F35E5-161D-4D28-A9E4-5549603A2F00] - Engine [1] Status [IDX_DB_ERROR] - Reason [Log restore failed for Job 43940]
12512 3444  10/10 20:05:45 ### DB [022F35E5-161D-4D28-A9E4-5549603A2F00] - Engine [1] - Status [IDX_DB_RECONSTRUCTION] - ReconJobcount [252]
Best answer by Henke
@Mike Struening It was a collegue that created the incident.
Anyway it was solved by running the workflow “Enable Subclient Index” on the client that had issues.
Case solved.
BR
Henke
Hi @Henke !
I found a few incidents with this error, ranging from slow disks to a patched issue.
Can you confirm you are on the below versions or higher?  IIf not, updating to the proper level below is a good start:
11.23.16
11.24.2
11.25.0
Otherwise, I would open a support case as the other incidents all went to our dev team.
@Henke , can you confirm if you were able to update to the mentioned versions?  If so, did that resolve your issue as expected?
Henke
Novice
  • November 2, 2021
Hey @Mike Struening ,sorry for not getting back.
We are on 11.24.7.
It seems to be a corrupted Index and we opened a support ticket for the issue, it’s being worked on.
//Henke
Thanks for the update!  Can you share the case number?  For some reason I’m not finding it.
Henke
Novice
  • November 3, 2021
Case solved.
BR
Henke
Thanks for sharing, @Henke !!
