client v10 not backuped after upgrade CommServe to v11SP28
  • October 25, 2023
  • 122 views
We have client with oldes oracle db and we must use agent v10, but after upgrade commserve and media agent to 11.28 backups stop working, error sugest that this is problem with network but it’s not true.
  • October 25, 2023
Hi Pawel,
   Can you try this?
Prakash
https://documentation.commvault.com/2023e/expert/160819_troubleshooting.html
Add the bPre11Clients Additional Setting if You Have V10 Clients in Your CommCell Environment
Due to security enhancements made in CPR 2023E, communication from a Commvault Version 11 MediaAgent to Commvault Version 10 clients will not work unless you add the bPre11Clients additional setting to the Version 11 MediaAgent.
  1. To the Version 11 MediaAgent, add the bPre11Clients additional setting as shown in the following table.
    For information about adding an additional setting from the CommCell Console, see Adding an Additional Setting from the CommCell Console.
    Property
    Value
    Name
    bPre11Clients
    Category
    CommServe
    Type
    Integer
    Value
    1
  2. Restart services on the MediaAgent.
