Cloud Mount Pathaccessibility
  • November 13, 2023
  • 64 views
Forum|alt.badge.img+16
Greetings all
I have a customer who decomissioned Commvault a few months back and they now need to recover some data.
The Commserve and Media Agents were deleted.
We intend to restore the last DR_SET backup that was taken to create a new Commserve and a new Media Agent (Linux).
The Library was configured as a NFS share and that backup data is still available in the cloud provider’s infrastructure.
In order to access the mount path, do I just share it in the ‘Sharing’ tab on the original Media Agent’s properties and then add the data path in the Storage Policy copy (wasn’t the primary copy).
The DDB is on longer available, but we wouldn’t need it just for restores.
We’re only restoring File System Data.
Is there anything else I need to consider?
Mauro
Best answer by Collin Harper
Hello @Mauro
I was thinking, after the DB is restored and the mount path shared, it might be a good idea to run a Data Verification or DDB Verification to make sure the data is recognized by the CommServe, since you are rolling back to a previous point in time.
Getting Started with Data Verification - https://documentation.commvault.com/2023e/expert/12372_getting_started_with_data_verification.html
Performing a Data Verification Operation on Deduplicated Data - https://documentation.commvault.com/2023e/expert/12569_performing_data_verification_operation_on_deduplicated_data.html
Thank you,
Collin
Hello @Mauro
Once the CommServe DB is restored, simply share the new MediaAgent to the mount paths of the Cloud Library.
Thank you,
Collin
  • Challenger
  • November 14, 2023
Hello @Mauro
Thank you,
Collin
Thanks so much. I thought as much, just wanted to confirm before I proceed that that was all that was required.
  • November 14, 2023
Hello @Mauro
Thank you,
Collin
