Cloud Power Management
  • December 14, 2022
  • 185 views
Hi Community,
When looking to utilize Cloud Power Management on Media Agents (in this case AWS), is there any considerations when looking to deploy 2 x node partitioned DDB Configuration?  I am trying to determine if there would be a situation where Power Management would power down one of the MA’s leaving only 1 x partition available causing additional bloat to the DDB and more data getting written to the Cloud Library?  I would assume that they would be treated as a pair and either both MA’s would be on or off but not sure how the logic works?
Can’t find any information in Books Online so any help would be appreciated.
Best answer by Collin Harper
Hello @G.lee
Yes. In a multi-partitioned DDB configuration all required Media Agents will be sent “Power-On” requests.
Cloud MediaAgent Power Managementhttps://documentation.commvault.com/11.26/essential/101313_cloud_mediaagent_power_management.html
Support for Operations
Operations for Which the System Automatically Turns On Cloud MediaAgents
Power management turns on cloud MediaAgents for the following operations:
  • Auxiliary copy operations
  • Backup operations
  • Restore operations
  • Pruning operations
Thank you,
Collin
  • December 14, 2022
Hello @G.lee
  • Backup operations
Thank you,
Collin
  • December 14, 2022
Thanks Collin - appreciate the response
@G.lee
No Problem!
Thank you,
Collin
