Command Center equivalent of Commcell Console - Scheduler
  • January 13, 2023
  • 24 replies
  • 984 views
Hi
Running 11.24.73
I have a new colleague that has been trained in ‘Command Center’, I’m someone with many years experience in ‘Commcell Console’
Is there an equivalent in ‘Command Center’ of the Commcell - Scheduler?
Just being able to see what jobs are due to run and when in the future
I spent a few minutes looking around, couldn’t find anything!
Many thanks
Mark
Hi Mark,
No, unfortunately there is no option in Command Center that shows the details of the start time of any planned tasks within the CommCell. This is I think to be seen as an advanced view which requires the CommCell console.
One thing you can do in case you are still using traditional schedule policies and storage policies is the setting the following additional setting which add a button in the side-bar within Command Center allowing you to see the schedule policies.
https://documentation.commvault.com/additionalsetting/?q=showpolicies
Onno
Forum|alt.badge.img+16
  • January 13, 2023
Hi Mark !
I’m running v11.28.44 and still don’t have such view/report.
Laurent.
Onno van den Berg
Hi Mark,
Onno
chrisknows
Novice
Forum|alt.badge.img+9
  • January 13, 2023
That additional setting is worth its weight in gold.
Thanks.
  • January 13, 2023
Hope it’s not adding too much load/weight on the webconsole server, though 🤣
I’ll let you implement it and will wait for your feedback before adding it on my side 😁
Scott Moseman
There was a Schedule Policy Information report which had Schedule Pattern and Next Schedule Time as columns in the report.  But I don’t see the report on Commvault Store anymore.
Scott
Onno van den Berg
Not sure why you think it will add more load. Just like any other section will it just pull all the information via the API from the CommServe just like any other view.
  • January 17, 2023
Thank you everyone for your feedback!
This will help me considerably in my communications with my new colleague
Thanks again
Mark
  • January 23, 2023
Hi all,
I’m not seeing the “showPolicies” in the Additional Settings in the Commcell Console. I am only seeing the “showPlan” option which I dont believe is what I want. Has it been removed?
Enrique
Onno van den Berg
@eflores this is a hidden setting and believe me there are many. many more!
  • January 23, 2023
@Onno van den Berg is there a way to unhide the setting?
Onno van den Berg
@eflores no, this is a hidden setting and just wasn't added and released as a public setting in the settings library. I also think this is the best approach as customers should move to plans. I honestly also encourage Commvault to make this transition for all customers in the near future. Right now you can do it already using a workflow. So the showpolicies option is just there for a temporary period and for customers who still need to migrate to plans.
Gaetano
Novice
  • February 22, 2023
should this setting be enabled at CommCell level? I did that but nothing new appeared in the side-pane of the Command Center.
Onno van den Berg
You will have to apply it on the servers running Command Center.
Gaetano
Novice
  • February 22, 2023
Yep,
it is there. I added it to the Commserve host which is the one running Command Center.
May you show me how the button looks, please? Unfortunately still can’t see it :-(
Onno van den Berg
Yep,
It might be that you need to update the navigation preferences, because you might need to enable the policies section. If configured correctly you should find the Policies section under Manage.
@Onno van den Berg  - great feature - thanks for this - any other hiden functions like this are knowed ?
Command Center is the future but it should bring up another functions as well which the cc console have it :)
  • April 11, 2024
Hello @Onno van den Berg  ,
I want also  to use this additional settings and I don’t see this option  - show policies in the additional settings of  commcell
commserve version : 11.28.102
thanks.
Onno van den Berg
@ariel_b yes that could very well be the case as this could very well be a hidden key. Just fill it in as displayed and it should work.
  • April 11, 2024
I can not see this additional setting in the commcell
can you send me a kb or something like that ?
Onno van den Berg
As I said you won't see it and there is no public information….
Erase4ndReuseMedia
Just for reference, as of 11.34 showPolicies is reportedly no longer available.
The showPolicies additional setting is no longer available and the users will not be able to view, add, delete or use any schedule, storage or subclient policies from Command Center. You can convert the storage policies to server plan. Also, the exisiting policies can be accessed from CommCell Console.
We’re continuously working to add all relevant functionalities that are currently missing in Command Center, with schedules and schedule policies being one of them.
In 11.36, below changes are made to make it easier for existing customers that currently use storage policies and schedule policies instead of plans:
  1. Policy to Plan app is updated to create Plan for each storage Policy. It will not try to convert schedule policy and pull that configuration as the RPO in the plan. Schedule policies stay as before.
  2. Schedule policies (Data protection ones only), can be viewed and modified via Manage > Backup Schedules option.
  3. “​​​​​​​Backup Schedules” menu under “Manage” is behind setting “showSchedulePolicies”. If you use Policy to Plan app, the setting is configured automatically. You can view backup schedules in Command Center without running Policy to Plan but must enable the setting manually. Related doc link: https://documentation.commvault.com/2024e/essential/creating_data_protection_schedule_policy_in_command_center.html
    We're working to add schedules beyond data protection ones to Command Center soon.
  • October 30, 2024
Hi @Divya Trivedi,
Will the Advanced backup options be available or is it planned to add them? I am interested in the Media options: https://documentation.commvault.com/2023e/expert/advanced_backup_options_media_01.html
Hi @Ledoesp - Advanced backup options for Media are currently not available in Command Center. There is ongoing discussion to add “Start New Media” and “Mark Media Full on Success” options only. If your requirement is to add more options, can you please raise a support ticket requesting a CMR to be created.
