Commerve livesync with pre-installed CSDB
  • May 11, 2023
  • 84 views
Forum|alt.badge.img+5
Dear All,
I’m currently deploying a Commserve in CIS hardened Windows server 2019. I want to preinstall SQL server to add a specific SQL instanceName.
on the standby commserve when i will install the failover package, what’s the installation method ?
Should i do the same as the active Commserve and preinstalling SQL with the same SQL instance name ?
thank in advance for your help ?
Christophe
Best answer by Ledoesp
On the standby CommServe there are three steps, same as in production CommServe:
  • Preinstall the SQL Server
  • Install the CommServe
  • Install the Failover package
  • May 11, 2023
  • May 11, 2023
Dear All,
Christophe
Hello Ledoesp,
thank for your reply.
kind regards,
christophe
