I have configured SAML authentication on the Command center and an ADFS server for a domain.
Everything works but there is one small thing i don’t get to work.
If i logon and enter the username the redirect to the ADFS servers works but, i need to enter the username a second time. Is there an option to send the username with the SAML redirect?
What feature release are you on, it shouldnt be prompting for username the second time.
This is what i get with the command center:
This is what i get with other applications:
Or that you enter credentials at command center and have to re-enter at the ADFS redirect itself?
Does this behavior work the same way with your other applications using ADFS?
Or that you enter credentials at command center and have to re-enter at the ADFS redirect itself?Does this behavior work the same way with your other applications using ADFS?
Sorry for the late answer.
- I give in my username on the command center.
- The command center redirects to the ADFS login page.
- On the ADFS page i need to re-enter the username on the login page.
With other software like office 365 i don’t need to re-enter my username.
No problem,
To summarize then, we are not passing along the login attempt to the ADFS page.
Unless others have ideas, I would suggest opening a support case for this issue. Let me know the case number so we can track and update this thread.
Hey
Hey
