Commvault Command Center does not show PostgreSQL databases
  • September 23, 2021
  • 220 views
ibrahimemrekaya
Explorer
We are backing up PostgreSQL systems with block-level at customer site. We are doing individual db restore from commcell console but our customer wants to do this from command center. In Instances tab i can see PostgreSQL instances but in Databases tab it says no results found. Is it possible to see PostgreSQL databases in command center like MS SQL databases?
Commvault version is: 11.20.60
Instances
Databases​​​​​
Best answer by Meera
Hi Ibrahim,
Database level restores from block level backup is not supported from command center yet. Only full instance restores are supported. Do you have dumpbased backups also run?
Meera
Meera
Hi Ibrahim,
Meera
ibrahimemrekaya
Explorer
Hi Meera,
I hope you are well.
Thank you for your answer. No, we are only taking fsbased block-level backups.
Meera
Hi Ibrahim,
Please contact commvault support team and create a CMR to add this support. We have it planned in roadmap but no ETA. You can track the support with the CMR
Meera
ibrahimemrekaya
Explorer
Hi Meera,
Thank you very much.
