Commvault express installation
  • March 12, 2021
  • 379 views
Hello community,
Is there someone that has already install Commvault Express for lab/test purpose ?
I cannot login to the console after installation and i cannot create an account from the WebCOnsole.
Any tip/idea ?
Alessio
Best answer by Alessio
Dear all,
i fix using mozilla and not IE.
Thanks to all.
Alessio
Anthony.Hodges
Certified Expert
Forum|alt.badge.img+9
I've seen issues when the Workflow Engine Service is in a loop, sometimes because the connection string/password for the commvault database in the registry are not set properly. Have you tried a repair installation?
Hmm, I’m not sure what would be causing the problem here. You said webconsole but can you try https://localhost/adminconsole ?
Maybe if it's helpful, there are also pre-built VMware images with OS + CV already deployed:
Download and documentation.
Hi @Alessio
Are you getting any specific errors when attempting to login?
Knowing the particular error message will point us towards a couple of possibilities to help out.
Stuart
  • March 15, 2021
Dear all,
Thanks to all.
Alessio
