Commvault Linux package creation automation
  • 2 June 2023
  • 382 views
Hi Folks,
we need to create quite a lot of custom packages (rpm) for linux clients on a regular basis (SAP-Oracle, SAP-Hana, Linux-fs, and so on.)
We are currently doing this via ./cvpkgadd and then clicking through a lot of pages until the custom package is finished at the end. is there a way to automate this process via some command line where all necessary options (most of them can be left at the default value) are provided (which packages to include, to which commserve to connect to, ...)?
Thanks for any ideas on this :)
Badge +13
Hi @Alex Zett
You can use unattended install using an answer file.
Please check the documentations → https://documentation.commvault.com/2022e/expert/2083_unattended_installation.html
Let us know in case of any questions.
Gowri Shankar
