What are the implications of running LiveSync across 2 sites each with a CommServe and automatic failover set to occur? In the case of a Primary CommServe failure I see no issue and expect the monitoring nodes (both sites) to trigger transfer of the primary function to the CommServe at the other site.
However… What if site A becomes isolated from site B with a network failure between both sites? I expect the Primary Commserve continue to run its site but will the CommServe in site B become active at site B as well with the monitoring nodes there losing connection with the CommsServe at site A?
Will this result in a “Split Brain” condition across both sites??? If so, what happens on network reconnection???
