We are experiencing a challenge with Commvault and PostgreSQL in a clustered environment and would like to ask if there is a supported or recommended approach.
Environment
PostgreSQL cluster with 1 Master and 3 Standby nodes
Automatic failover managed by Patroni
Commvault PostgreSQL agent is configured at the cluster level
Current Behavior
Commvault is able to detect failover events correctly.
However, when the Master role changes, Commvault does not automatically prioritize the new Master node for backups.
After a failover, we must manually move the new Master node to the first position in the cluster client configuration.
Is there:
A native Commvault feature, or
A supported best practice
that allows Commvault to automatically switch backup operations to the active PostgreSQL Master node after failover, without requiring manual reordering of cluster nodes?
