CommVaultRegistryBackups
  • June 6, 2025
  • 72 views
Forum|alt.badge.img+16
After each linux update i am seeing this msg belove, what is this exacly and can i store it on /opt/hds location instead at etckeeper??
39 files changed, 130 insertions(+), 23 deletions(-)
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250121082400.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250128033422.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250128042923.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250128052422.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250128061923.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250128071422.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250128085924.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250128095423.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250129025925.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250129030925.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250129031425.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250129031924.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250129032425.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250129032925.gz
 delete mode 100644 CommVaultRegistryBackups/Instance001/20250129033425.gz
 rename CommVaultRegistryBackups/Instance001/{20250129023424.gz => 20250129035925.gz} (100%)
 rename CommVaultRegistryBackups/Instance001/{20250129023925.gz => 20250129045424.gz} (100%)
 rename CommVaultRegistryBackups/Instance001/{20250129024425.gz => 20250129054424.gz} (100%)
 rename CommVaultRegistryBackups/Instance001/{20250129024924.gz => 20250129063925.gz} (100%)
 rename CommVaultRegistryBackups/Instance001/{20250129025425.gz => 20250129073424.gz} (100%)
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129082925.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129092424.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129095425.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129095924.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129100425.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129100925.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129101424.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129101925.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129102425.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129102924.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129103425.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129103925.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129104424.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129104925.gz
 create mode 100644 CommVaultRegistryBackups/Instance001/20250129105425.gz
 create mode 100644 scoutfs/archset-d.yaml-from-cron
Best answer by Egor Skepko
We are created symlink to /opt
  1. stop commvault
  2. mv /etc/CommvaultRegistryBackups /opt/commvault
  3. ln -s /opt/commvault/CommVaultRegistryBackups /etc/
  4. start commvault
CV_GK
  • June 9, 2025
Hi ​@Egor Skepko
After which version to which Linux update, this issue is observed and what is the CV version on affected clients?
  • June 9, 2025
Hi ​@Egor Skepko ,
From the above logs. it looks like the update is currently processing a backup of the registry and will clean up the backup once the installation is complete.
  • Challenger
  • June 10, 2025
@Pradeep ,
Can we move it to the installation location instead keeping at etckeeper location?
@CV_GK  We are running CV on 11.36.55 and mostly on solr i am seeing it
  • June 10, 2025
@Egor Skepko ,
Etckeeper will help track changes to configuration files, Hence moving them outside is not recommended for now.
  • Challenger
  • June 10, 2025
@Pradeep Why not recommended??
  • Challenger
  • August 26, 2025
  1. stop commvault
  4. start commvault
