Converting synthetic fulls to traditional ones if failing?
  • May 11, 2023
  • 71 views
RubeckDK
Explorer
Hi everyone..
Do such a setting exist? I mean, if a Synthetic Full backup job fails is there a way that it can convert it to a traditional one on the next re- try?  FS and VSA jobs are the ones, I’m interested in…
Thank you in advance..
Kind regards
Rubeck
Best answer by Hyder
Were you able to find out why the SynFull job failed?
Usually you can just run a Full manually or you can change it in the schedule, there’s no “conversion” its just the job type you want basically, is this what you’re trying to figure out?
Hyder
  • May 12, 2023
