Copy from Tape to Disk
  • January 5, 2023
  • 707 views
We have LTO4 tapes that contain backups that we would like to move back to disk. Is that possible? If so, how can it be accomplished? Thank you for your time!
Best answer by Collin Harper
Hello @B745639468
You can setup a new aux copy within the same policy going to disk and set the “source copy” as the tape copy. The aux copy will read from the tape copy and write to the disk copy.
Creating a Synchronous Copy Using a Storage Pool - https://documentation.commvault.com/11.26/expert/118965_creating_synchronous_copy_using_storage_pool.html
Thank you,
Collin
  • January 6, 2023
Good morning.  Are you wanting to move the jobs back to the same storage policy with the same retention, or to a new policy that is associated to a disk library?
  • January 6, 2023
Hello @B745639468
Thank you,
Collin
