Could not get SIDB folders error on cluster drive
  • October 25, 2022
  • 627 views
Forum|alt.badge.img+9
I am backing up a cluster, but each cluster drive has its own subclient
All the other drives on their own subclient are backing up fine.
There are 2 errors I see.
  1. Process(72) - Could not get SIDB folders; cannot exclude SIDB folders from this backup
  1. ERROR CODE [17:49]: Failed to further divide the collect files. Possible reasons: nonexistent path/file, hardware problems or full disk.
The job for the cluster subclient run for over 30 hours before failing.
The check readiness indicates there is no error on the sublient,
Anyone have ideas on what logs I should look at the find the root cause.
Best answer by gary mcneely
SOLVED:
the reason for this particular failure was the drive the job results folder resides on is FULL.
  • October 25, 2022
Hi Gary ,
Great name BTW :)
is it hung on the scan phase of the job?
check the output of command “vssadmin list writers”
you may just have to reboot that client to clear it up.
Hello @gary mcneely
The errors indicate some issue with the DDB. Can you confirm:
  • The DDB partitions are reporting online in the GUI?
  • The DDB drive on the Media Agent is connected and online
  • The DDB Files exist in the location they are supposed to be on the drive
  • You can check clBackup.log & SIDBEngine.log on the Media Agent for further errors
  • Confirm AV exclusions are in place - https://documentation.commvault.com/11.23/expert/8665_recommended_antivirus_exclusions_for_windows.html
  • Confirm if you have a log on the Media Agent called “DLPAlerts.log” and if so, when was the most recent update to the log?
Thank you,
Collin
  • November 9, 2022
SOLVED:
